i'd have to see a picture of the insides of your ecu.. generally on obd1 ecu's there are some RP jumpers to remove and add in another position.
since its a JDM ecu, the jdm p30 ecu i chipped a while ago had all surface mount components.. i dont remember if it had the RP jumpers or not.. i'm not sure if the p13 has all surface mount components like the p30... i would really need to see inside the ecu.
Originally posted by 95preludetypes@Feb 29 2004, 03:26 AM Is it possible to change an auto jdm p13 ecu and change it in to a 5 speed can i just chip it or is there something else i need to do thank you
then you haven't been using the right programs, Pills.
A lot of the blue-blood Japanese racing programs (real Mugen, Spoon, etc.) disable the check for the auto trans in software - you can put them in an ECU that is configured for auto trans circuitry and it will act like a 5 speed.
i hadn't been trying to convert anything... my ecu tunings are few and far between these days.. just the group of friends with hondata etc. and a few using CROME... but we all have 5 speed ecus already
