p13 ECU on a H22A8....will it work????
il3g4l
hey ppl,
I have a h22a8 euro type 200 hp to instal on my 94 lude vtec, and i'll like to know if it will work with
my p13 ECU????and harness?? (I know the h22a8 works with the p5p ecu)
tnx alot :worthy:
H22A8 is OBD2, P13 OBD1 <-Solution: harness conversion
BUT
IAC is different. I think the Euro R is using 3-wire and P13 ecu only accomodates 2-wire.
Euro R VTS does not have the oil pressure switch if I am not wrong. P13 ecu will certainly flick a CEL 22 for missing oil pressure switch. Check your H22A8 VTS for oil pressure switch.
Get a P5P ecu. If not available used, get a new one from the dealership for about 800-1100 bucks. Stock rev limit for the P5P should be in the mid to high 8Ks.
