p28 ecu for h22 questions
Discussion in 'Prelude' started by Taog36, Mar 31, 2011.
  1. Taog36
    Taog36 New Member
    I'm swapping out a h23 for for a h22a in my 94 prelude.
    I need a ecu. A chipped p28 sounds legit to me.
    Xenocron Tuning: Chipped OBD1 VTEC ECU. #[P28-Equiv]
    When i order one, i need need to get a base map for h22a 94 prelude? I want to make sure im on the right track and im doing this right.
    So if i get that, is the base map gonna be an improvement from default factory ECU and give me better performance or am i going to have to have a turner make adjustments for me to get an increase in performance? The car right now will only have custom exhaust redone and cold air intake, maybe after market headers and/or cams. I plan to do more work on the engine this summer. What im not gonna know is this ECU gonna perform good with the stuff i have done to engine or is it gonna be on factory settings, thinking my car has factory intake and exhaust.
    When i add more to the engine ill have to tune it again right, to take in the fact i added an up grade?
    Also when i put the ecu in, the car should start up and run right? so its at least going to be drivable, just maybe not best performance?
    thanks for you help.
  2. reikoshea
    Dallas, TX
    no need for this thread. keep it all in your old one.
