P28 ECU problems *urgent*
ibanender
I just swapped my D15D6 out of my 90 CRX for a D16Z6 out of a 94 Del Sol. I got the OBD1 adapter harness, got it running fine and drove it home. After I start it once and shut it off, it WILL NOT start again and throws code 15 (ignition output) till I reset the ECU. I reset the ECU and it will start and run fine, I shut it off and it wont start again. The P28 was an automatic and I converted it to a manual properly from what I've seen. I've tried removing RP17 and RP18 with a jumper on RP18, and I've also tried RP17 removed with the resistor on RP18. Any way I do it, it still does the same thing. I tried an ECU somebody else had that he had modified taking just RP17 out and the car ran fine and started every time. Anybody know where my issue is?
