p28 ecu
Discussion in 'ECU's, Electronics, and Tuning' started by calvin, Oct 8, 2002.
  1. calvin
    calvin Senior Member
    NETHERLANDS
    can the p28 be chipped without soldering?
    Because the p30-g00 and p30-g01 can be chip just by putting new rom chip i think.
    Thanks
  2. CRX-YEM
    Wallingford, CT
    p28 cannot be chipped w/o soldering
    that I know of
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    it is an IMPOSSIBILITY to do it without soldering nearly 30-35 locations... just solder it damnit!
  4. pills_PMD
    New Albany, OH
    and those other ECU's also require you to solder in a jumper, a resistor a 20 pin ROM and a 28 pin socket that you can then just plug the new ROM into
  5. calvin
    NETHERLANDS
    Does anyone has some sites, how-to, instructions??
    Has anyone done this before? Is it difficult?
    THANKS
  6. pissedoffsol
    i do at home in my book marks... shit.
    its on anglefire.com some where... if some one else has it, post it, or amybe search on angel fire... i'll see if i can find it tonight
  7. calvin
    NETHERLANDS
    Thanks brian.
  8. pills_PMD
    New Albany, OH
  9. calvin
    NETHERLANDS
    thanks
    does anybody know if the ecu in the netherlands are different then the us.
    Because i saw a frien of min his p30 and it was not the long one like the usdm
  10. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Yes, the european and japanese ecu's are different from the US ones.
    They are the short box versions, and require a bit more work to chip.
