S sihondatech New Member Jan 11, 2008 #1 Will a virgin sohc p28 ecu run a b16 engine ?? Cant get the car started!!!!!!
dtob New Member Jan 12, 2008 #3 Might get it started but I wouldn't try it. Get it chipped or buy a proper ecu. Why don't you try it and let us know.
S sihondatech New Member Jan 12, 2008 #4 i put obd1 b16 into 93 delsol si sohc vtec.using the stock p28 the car wont start.it wants to but it wont. y??????????
dtob New Member Jan 12, 2008 #5 It's the wrong ecu.... Get a p30 or chip the P28 and have a P30 map burnt to it.
S sihondatech New Member Jan 12, 2008 #6 will a obd1 p72 run this car except for iab check engine light?? i have a 94 gsr ecu to try.
dtob New Member Jan 12, 2008 #7 Give her a try. It will not be using the proper fuel map but should run the car. Also you will have the iab cel like you said.
