Mark Pozzobon uses Crome + a stock ECU to win the naturally aspirated bracket.
Originally posted by Chet Hewitt OBD-1 ECU Comparison
So you are soooo convinced that you need a chipped ECU to go fast.
You didn't listen to me when i said to get a hondata.
Well, here I will make one last effort to save you from spending your
money on an ECU chip and making your car slower.
SLOWER?? Yes, that wasn't a typo. Read on and find out why.
Chet has a usdm B16a3 with a JDM ITR tranny with a 4.785 final drive ratio, apexi world sport exhaust, comptech header, iceman air intake and a test pipe. So I think it is a fair assumption that this is a near stock engine. No internal modification, just bolt ons really. Chet has tried several ECUs in his car and had a chance to dyno each of them. What follows is a comparison of each of the ECUs that Chet had in his car. You will see that for a near stock engine the best ECU is the one that came with it. Chet used a skunk2 chipped P28 ECU, a P61 ECU and finally the P30, which is the original ECU that came with the b16a3. All of this was done on a Dynojet. It should be noted that the p30 was dynoed when temperatures were 20 degrees warmer. 80's vs. 60's, so that may account for a slight variation in numbers. Also, the 4.785 FD ratio has been known to produce a decrease of 2-5 hp over the stock 4.40 FD ratio. All of the runs were made with this 4.785 Final Drive ratio.
In the following charts, the color codes are as follows:
green - skunk2 P28
blue - p30
red - p61
This chart has a comparison of ALL 3 ECUs that were tested compared side by side.
This next chart include an air:fuel curve comparison between the p61 ECU and the skunk2 ECU. Notice how the skunk2 ECU goes to 10:1 !!!! That is running INCREDIBLY rich, which is very unneccesary. Chet said he got 18 mpg with that ECU. He makes his peak HP of 144 and the p61 makes 150 whp while keeping an air:fuel ratio of near 13.0:1 and goes to 12.0:1 near redline. Hondata even suggests and has noticed a trend that peak power is obtained by tuning a ratio of 13-13.5:1 a/f. So with an ECU like hondata, Chet could easily gain some peak power by leaning out his mixture. By raising the VTEC crossover, he may even be able to smooth the slight dip right at the point when VTEC engages.
Finally we have just a view of the results of the p30. Notice the smooth curves.
