p2j ECU 3stage vtec
Discussion in 'ECU's, Electronics, and Tuning' started by snowy, Oct 15, 2005.
  1. snowy
    snowy Junior Member
    Hi,
    I've been searching the net for days looking for pinouts for a db15b 3stage vtec ECU... does anyone have the pinouts for both manual and multimatic tranny?
    p2j-003 (manual)
    p2j-j61 (auto/mmt)
    thanks
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    never heard of 3 stage vtec let alone a ECU for it.
  3. reikoshea
    Dallas, TX
    3 stage vtec = vtec-e. its that wacky thing they put on some civics and the insight to save gas...basically it has the opposite effect of vtec. you get better gas mileage at the cost of power.
    Steve at hmotors has a lot of connections, call him up see if he can hook you up. from what i understand that ECU is JDM only.
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    its actually vtec-e+regular vtec [​IMG]... fuel economy as good as the vtec-e's but as much hp as the ZCs(around 130hp).
  5. stinksause
    stinksause New Member
    Everyone is looking for that ECU ... especially for manual. 95% of the cars that came with the d15b (3 stage OBD2) were CVTs = manual ECU is ULTRA RARE.
    3 stage vtec works like this
    0-2500 rpm - you are using only half of your intake valves (12 valves active) - GOOD Economy
    2500 - 5500 rpm - you are running regular non vtec timing (all 16 valves active)
    5500 - redline - high profile (one of if not the most aggressive timing on a stock d-series cam)
    JDM Engine Depot has auto P2Js, I am pretty sure the pinouts are VERY simmilar if not identical, problem is that the maps are a bit different for an auto, and you will not have vtec engaged unless you trick the ecu into thinking it is in D.
    result: ~130 horses, 102 f-lb tourque
    more power than a d16y7 and 1 less f-lb of tourque
    pretty much almost twice the fuel econ if you are not beating
    theory suggests that going constant ~45mph with optimal tranmission gearing yields 70 mpg which translates to like 40 to 50 mpg during regular driving. TAKE THAT, PRIUS!!!
    If you find one, let me know, I am trying to do this swap in my 2000 civic (stock d16y7 engine)
  6. stinksause
    so you are getting the power and tourque of a reg 1.6 littre, but with a 1.5, and on top of that with vtec-e!!!
