p30 ecu
h1coupe
Member
hello guys!
i have a p30 ecu from a 92vti civic and i can get a motor from a 96-98vti! is there a difference in the ecu´s or does the p30 work for all 92-00 b16a2 motors!
i know they all have p30 but is the map different or is it different cause of obdI-II ?
you could make it work.. but any engien post 95 is going to be obd2 then you run into the obd2 to obd1 conversino problem.. it all depends what car you are going to put it into...
