P30 with eagle rods LS Vtec
Discussion in 'Engine Building' started by vbspec, Feb 17, 2009.
  1. vbspec
    vbspec New Member
    Hey guys I'm sure this has been asked a billion times but I cant seem to find it. I'm building and LSvtec with a B16 head and would like to run p30 pistons. I also know that it is advised to use a better rod of spend a bunch of money on stock rods (I'm not really fond of that idea). If OEM P30 pistons wont work with an Eagle rod is there another piston MFG that will give me the clearances I need to run an "aftermarket" rod with the same compressor ratio?
    Thanx for taking the time.
  2. Taco15
    Tallahassee Fl
    yup. any aftermarket brand will work.eagle,wiseco,etc. as long as you make sure the cleareances are good when installing the cams then your alright.
