P72 head/b18b block & ctr pistons
Discussion in 'Engine Building' started by crxlsvtec1221, May 15, 2005.
  1. crxlsvtec1221
    crxlsvtec1221 Member
    Philly,PA
    I currently building another lsvtec and I have a p72 head and a b18b block and thinking about throwing in some ctr pistons I was told that compression would be at 12 but now im being told that the compression is goin to be at 13. I know I have to retard the timing and all but I'm thinking now this wont be a good daily driver
  2. brian11to1
    brian11to1 Senior Member
    no. with a 3 layer hg you're looking at 12.3:1.
  3. crxlsvtec1221
    Philly,PA
    thats the golden eagle head gasket or the oem head gasket
  4. brian11to1
    no, i used the thickness for an oem headgasket...
  5. GSRCRXsi
    MD
    compression is more like 13+
  6. brian11to1
  7. formby
    formby learning in progress
    because the piston sits above the deck....
  8. crxlsvtec1221
    Philly,PA
    so should I do it or get another set of pistons, and If i do go with the ctr's what other procedures do I go thru, as in parts or block modification
  9. crxlsvtec1221
    Philly,PA
    Im planin to go all motor and I would like to make it a daily driver, I dont mind sacrifing gas milage
