P73 ECU
Mr_GaBIG
Hello,
I have a '99 B16A2 motor and have a '99 P73 ECU sitting in my room.
Will there be any benefits from changing the ECU?
Also, what else will be needed for the ECU to fully function?
Thanks :D
Probably better than the stock maps in the si ecu, but getting an obd2-obd1 conversion + hondata and a tune would be much better.
is it a jdm or usdm. if its a usdm you might have problems, the usdm has a immobilizer in the unit and is actuated by the ignition in typr r vehicles only. the jdm should be fine. Running the itr ecu ? depending on your compression is how it will function. I tried to run one of these in my wifes ls/vtec with 9.4 compression. The fuel mapping was too rich so it ran like crap. You also have the alternative to add a vafc controller too just in case. p73-ao2 etc = usdm, p73-oo2or 003 = jdm.
good luck.
ok maybe i put my foot in my mouth you have a 99, thats the ob2b. thats a different story. oh well the jdm and usdm is still the same , along with the fuel mapping.
Originally posted by Mr_GaBIG@May 5 2004, 11:13 AM
Hello,
Thanks :D
what year is you car?
btw, if that P73 you have is US spec, there's no such thing as a US '99 P73 ecu. Acura stopped production on Type-R's in 1999.
:withstupid:
USDM = 97 - 98, or 00-01
jdm speed cut sucks. whats done to your motor to think you need maps of a motor making nealry 50 more CHP?
