Dark93DX
From what I've been able to gather from searching around is that some B20's came with a P8R Non-vtec head that has an 84mm bore, with larger ports and vtec sized 33mm valves.
Other then the fact that the vtec head comes with more aggressive cams/valve train wouldn't it be pretty close to the P8R head in terms of flow measurements?
Would a b20 with a P8R head & more aggressive cams be basically the same thing as a b20/vtec? or am I missing something here?
Cheers,
Cheers,
