Painted Interior......
Discussion in 'Body / Exterior / Interior / Cosmetics' started by 801CRX, Feb 28, 2007.
  1. 801CRX
    801CRX Got Rice?
    UTAH
    Ok, some of you may know that my first CRX Hf was totaled. So I got ahold of another 89' Hf.
    But my problem is that the interior looks ugly as a mutha!
    Its in great condition full interior no tears or anything major.
    The guy I bought it from painted it black and red, and I was wondering what is the best method to take the paint off of the interior panels?
    Thanks in advance!
  2. bistec
    bistec Project EH23
    My sol interior was yellow and blue. I've just repainted it black.
  3. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Try some paint reducer. Goto an autobody supply place and buy it, its not as strong as thinner but strong enough to remove the paint.
  4. 801CRX
    801CRX Got Rice?
    UTAH
    Yellow and blue WTF?
    Ive heard about using brake fluid to remove paint. But dont know what kind of affect its going to have on the panels.
    And I dont want paint on the panels kinda too ricey for me. Stock FTW
  5. delsoul
    delsoul honda hooker
    Eugene, OR
    Do you know what kind of paint was used? There is interior rattle can paint.. I have used that before, years ago (dumb idea really).
    Really, I would almost think the interior is ruined, but rather than trying to scrub it off.. try to allow whatever paint thinner you get to soak into the painted area.. that should break the paint down, and nearly flake off on its own.
    I would be wondering why the guy painted it in the first place for, too.. might be poor conditioned panels, faded or something.. you might end up having to repaint them anyways.
  6. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    well if he painted the panels like my buddy, he probably did a good bit of sanding to remove the texture. Keep that in mind; I'd just repaint
  7. 801CRX
    801CRX Got Rice?
    UTAH
    I dont know what type of paint he used, But my guess would be regular spray paint cause it looks like shit!:mad:
    He didnt sand it you can still see the texture through the paint!
    If all goes wrong(paint reducer,thinner, brake fluid and stripper) im just going to repaint the whole thing black.:D
  8. Turbo&Auto
    East Burg, PA!
    Most likely the panel is going to be dulled when you remove the paint, either from him scuffing before painting or from the thinner you're going to use. I've found that Krylon semi-flat Black looks a lot like black plastic OEM panels. I used it on the Accord gauge pod I made where the center heater vents were. The Krylon matched it almost perfectly :)
  9. d17type-R
    d17type-R Doc Brown says
    Langley BC
    I've heard that no matter what was previously used, You can get a primer from SEM that seals it all up and make the surface receptive to new coating....
    I've used SEM products and from day one they have been great!
    ..Either way you slice it... it's gonna be tedious, and it's gonna take time.
    um, YEAH!.... Best of Luck with that!:D
  10. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    i woulg use a good addhesion promtor, then a good primer with flex additive, then a paint with flex additive, then a clear, Be it gloos or satin
  11. Turbo&Auto
    East Burg, PA!
    SEM flexible primer surfacer works on almost any surface and makes it paint ready, I use it regularly :)
  12. hcivic.com
    YA but why buy an epensive primer when you can run cheaper primer with a flex additive
  13. d17type-R
    Langley BC
    Cheaping out will only yield cheap results.... so if you want you're finished product to look like you paid the Special Ed class kids to do it..
    (no offense, I think they're ALL wonderful lil Picassos just waiting to happen)
    ....then don't cheap out on product. Trust what the Industry Professionals swear by. And it's not just cuz I was employed by someone to do this for the last 8 years. They use SEM on Unique Whips, Gary Biggs from JBL uses it, Fishman uses it, ..... I could go on but it'd be like:deadhorse: .
    "Do it right or pay someone else to do it"
    ...Oh yeah.... SEM comes in pretty much any color you want and it's made specifically for what you're doing...just thought i'd throw that in there.
  14. Turbo&Auto
    East Burg, PA!
    The spray cans of the SEM primer are like $12. A can of Bulldog($10) and then a cheap can of primer($5) will be more then that. How are you saving by doing it the cheap way again???? AND we're talking about a couple dollars not hundreds :roll:
  15. 801CRX
    801CRX Got Rice?
    UTAH
    Hey, I havent gotten around to it yet, due to a baby on the way.
    But hopefully ill get to doing it here in a lil bit
