PCT (CTR ECU) VS P73 (ITR ECU)
I have a 00 JDM B18c (ITR) swap into my EJ.. nd I'm running a PCT ECU from a Civic type R.. Is there any difference if I'm using this ECU with my setup rather than the P73? What affects does it have on my car's performance? ie: fuel curves, compression, power? thanks
yes. I would try to get a P73 instead of the PCT. It will have fuel + timing curves that will better match your motor. If you're interested in getting rid of the PCT, I need one for lab experiments.
