Peak and saturated injector obd0-obd1 questions?
louzerz
Hello, Im about 2 weeks away from doing a obd0 to obd1 converion in my 91 rex. The car currently has the stock peak and hold hf injectors.
Can I swap over the stock peak and hold injectors to my sohc zc vtec obd1 engine without complications from the p28 computer?
Thank You!
is the sohc zc vtec engine with p28 in the rex, or is it in a newer chassis. If its in the rex then yes you want to be using the obd0 injectors. If your talking about putting the obd0 injectors into say a 92-95 chassis then no thats not going to work.
88-91 chassis, yes, it'll work fine whether it's obd0 or obd1 converted. Your resistor box/injectors remain the same.
If you are trying to put an obd0 peak and hold injector into a 92-00 Civic, you will need to wire in a resistor box to make them work properly.
Ok Thanks a lot. I wasn't sure if the computer signaled a different amount of omn to the injectors but guess that would be converted by the resistor box. The obd conversion package that I got included a delete harness but since I can find peak and hold injectors cheaper and with a higher cc I'll just stay with the obd0.
