PG 6 76mm pistons
crxracer999
Hi everyone. Looking for some help here. Does anyone know of where i can purchase a set of 76mm PG 6 pistons. Looked all over the net - seem rally hard to find. Any info would be greatly appreciated.
Thanks for taking the time to read this thread
What I usually do is get the vehicle make, engine code, and go to and engine parts supplier and order in the size you need.. That really doesn't matter the cast marks in the pistons..
E
I don't think Honda allowed the engines to go to a full 1mm over bore- so you probably won't find an actual PG6 piston in 76mm. Most likely it'll be a custom job.
Back in the day, I used to bore out that big.. (EJ out to an EM1) Never had a problem. Just needed to keep an eye on the bores edge for sealing and then the cooling. But those were small engines too.
You don't think it's a spam-bot do ya?
E
