can you swap zc pistons into the y8? if so, does it bump up the compression? are there any other pistons that can be swapped? if not, what companies make high comp pistons for it? for around how much?
Not at all- just make sure that you can tune it well. Compression that high takes some precision to not knock on pump gas. What octane is available to you?
You might want to think about upgrading your camshaft to take advantage of the extra compression too. A more aggressive cam will really make your piston upgrade shine.
thats what i'm gona do this summer, i heard about it on honda-tech and the pistons are forged aluminum from the factory and fit perfect in a d16 or d15. i already got my head built and now i just need to do the block, then i puting on a td05 turbo and i'm gona run 10-15 psi (havent decided on an exact number yet)
oh, and that block posting lets you run at least another 3-4 psi of boost.
