Please help ASAP!
Discussion in 'Accord' started by Lord Helmet, Oct 26, 2008.
  1. Lord Helmet
    Lord Helmet Honda Noob
    Denver Metro
    This is probably stupid and maybe I am an idiot but how in the hell can I get the oil pan off of my 92 LX AT?
    All the bolts are out and the pan is loose. The clutch cover seems to be blocking the pan from releasing. I have taken the bolts out of the clutch cover but I can't seem to get it off. It's loose and I can move it around but I can't pull it off because it's bumping the oil pan. My repair manual does not mention the clutch cover and I haven't found any other imfornation that mention it either. So, I have put the bolts back in the clutch cover and attempted to pull the oil pan once again but the fucker won't come off. WTF???
    Can someone please help me? I have dismantelled Honda in my garage!
    Thank you in advance. Cheers!
  2. Lord Helmet
    Denver Metro
    Nevermind. A little TLC is all it needed. Thanks anyways.
  3. Ethan
    Ethan Well-Known Member
    Try Try Try and Again..... Before Posting!!! :)
  4. Lord Helmet
    Denver Metro
    I did, I did, and I did. Then I did again. It was no-go so I said screw it and finally used brute force. Again, my repair manual (as well as every other website I searched) stated it should simply drop right out once the seal was broken. Obviously not. Furthermore, I am not as familiar with these cars as many of you may be. A little direction is all that is needed sometimes.
    I'm highly familiar with forum posting etiquette and I aplogize for the worthless post, thanks. :thumbsup:
  5. BrutalB83
    Rochester Hills, MI
    Do you know what the definition of TLC is? It's not "brute force"...
  6. Lord Helmet
    Denver Metro
    LOL, yeah.
    Tuff croud here. :D
  7. Ethan
    all hail "brute force"! :D
