please help ive tried everything
Discussion in 'Civic and del Sol - EG and EK' started by 4doorsrock, Mar 24, 2009.
  1. 4doorsrock
    4doorsrock i drive a black misress
    greenback tn
    ive got a 1992 civic dx had a d15b7 in it i swapped in a d16y8 out of a 97 or 98 model i used the factory transmission and i swapped everything back to obd1 i changed the injectors the dizzy and the alt, so used the d15b7 wireharness. my problem is its gettin spark i tested it by pulling a spark plug and wire and layin it on the valve cover and i know its gettin fuel to the fuel rail but its not starting its just turning over.there are 2 plugs that are unplugged and i know there are supposed to be i think one went on the intake on the b7 and the other on the throttle body.if anybody can help me this would be helpful.oh and i know that the spark plug wires are plugged in right i looked at my buddies car to match them up so please help
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    Did you check your timing? What ECU are you running?
  3. 4doorsrock
    greenback tn
    ive checked the timing and im running a p28 im at my whits end
  4. haao13
    haao13 New Member
    PA
    im possitive but dont you have to change the injector clips
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    are the injectors firing
  6. 4doorsrock
    greenback tn
    im using the obd1 injectors and my wireharness from my d15b7 yea i think they are i got to lookin at it today in the rain 4 a sec and itghink i may have a plug of on the driver side.when i pulled on it its next to the cam dont really know wat it goes to any help
  7. 4doorsrock
    greenback tn
    i finally got it running but now when i give it some throttle it wants to cut out.if anyone has any ideas let me know
