Please help me with my Swap
CivcSniffer
I know this has been asked 100+ times but here i go. I put a d16z6 in my 97 hatch iam ruunning a jumper harness a p06 chipped for vtec hooked up vtec etc colour matched the the z6 dizzy to the y7 wiring the car starts but it idles rough and i have two codes tdc code 8 and ignigition output code 15. I think it has to do with my dizzy wiring can any one direct me to the proper way to hook up a z6 dizzy into th y7 harness thanks sorry if i repeated a question
Sound like the wiring on the dizzy. The dizzy sends tdc and ignition info to the ecu. The y7 is OBDII and the z6 is OBDI, you should have done a Y8 swap in your 97. Its alot easier to stick with the same OBD and it is a legal swap. Convertion from OBDII to OBDI is not legal. Rewire the y7 dizzy plug and use the z6 dizzy and get a OBDII to OBDI dizzy conversion harness, its plug and play.
