Please Let Me Out With A Distributor Issue
Discussion in 'HYBRID -> EG-EK / DC' started by bossman032, Apr 19, 2003.
  1. bossman032
    bossman032 Senior Member
    Ok here is my problem.
    I have a SIR II OBD1 JDM MOTOR came complete with Distributor.
    My Distributor is bad!!! I tried a 95 Del SOL DOHC Vtec Model the housing is different so that don't fit it hits my vtec senolid!!
    Fucken GSR Distributor is like 400+bucks + special order item fuck!! From autoparts stores in cali.. no one here wants to sell me just the fucken Distributor called motor swap stores..
    So I need help from GSR 94-95 owners please check your distributor's housing what number does your distributor's housing say please let me out I am stuck my engine is the car its waiting to be started!!! I need the number to just get an Idea if the the same as mine and will it work...
    MY Number: TD-44U
    this number is on the V shape bottom part of the distributor's housing!!!
    your help will be greatly appreciated :worthy:
    ronald
  2. D16z6CrxDx
    D16z6CrxDx Senior Member
    go to your loval parts storte they should tell you what cap you need to use..or just go to the dealer...
  3. solblu
    solblu Senior Member
    Ricer
    Just swap out the housings. Put your bad housing with the VTEC Sol insides.
