Recently I just swap my camshaft to a SOHC ZC's and I want to try out the 88-89 Integra PG7 ecu but worry that they are not really at all plug and play. Can I remove my Si PM6 ecu and just plug in the PG7 OR do I have to make some wiring changes?
be a little careful - there are two varieties of PG7.
88-89 PG7 are plug and play.
86-87 PG7 will not work.
They look pretty similar from the outside. 86-87 PG7 look totally different from your PM6 on the inside. look in the top-left corner of the ECU by where the wiring connects. If the board looks pretty similar there between PG7 + PM6 you're in luck. You can also check the date code next to the label on the outside, although some ECUs marked "87" are really 88.
