PM6 Ecu? Can i use this?
Discussion in 'ECU's, Electronics, and Tuning' started by Kracer427, Jan 4, 2004.
  1. Kracer427
    Kracer427 Senior Member
    Palm Desert, CA
    Planning on doing a d15 build up here but need to know what ecu to use.
    THE BUILD!
    D15 DX longblock
    High Comp Head Gasket
    VX (or ZC pistons would be even better) pistons
    CRX Si (a6) camshaft @ 4.75 zero'd out
    Civic Si (D16Z6) Intake Manifold
    PimpAss Bisimoto Header
    Now the question is CAN i use the CRX Si Ecu? Will the Ecu from a Pre-OBD car work on my OBD1 hatch?
    "so your telling me this coke bottle has more displacement than your engine? :huh: "
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    Stay obd1 and get a hondata. If you can afford a bisi header you should be able to afford the hondata. obd1 is a lot more tuner friendly that obd0.
  3. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    or get uberdata/crome. DIY tuning works very well in OBD1.
