Po6 questions
Discussion in 'ECU's, Electronics, and Tuning' started by civic94vtec, Apr 1, 2007.
  1. civic94vtec
    civic94vtec New Member
    i have a po6 out of a 94 honda civic dx d15b7 automatic and i jsut put a d15vtec manuel will this ecu work the with the new motor and run the vtec if i hoo it up to the A4 slot on the ecu
  2. pissedoffsol
    not without being converted. the p06 in default form is not vtec capable. however, the vtec board can be added on to it.
    the real problem is that its an automatic.... you'll need to convert that as well.
    your best bet is to just pick up the d15b ecu
