Poor-ass Racing Brake Install
Discussion in 'Members' Lounge' started by dohcvtec_accord, Mar 24, 2003.
  1. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Installed some slotted Brembo rear rotors this weekend, along with some Hawk HPS pads at all 4 corners.
    A photo of the old rotors:
    This is how bad the old pads were. I wish I had taken a better pic, the pads were nearly worn away in the rear. The fronts had some heat stress cracks in them:
    The new rotors, waiting to be installed:
    The new pads, waiting to be installed:
    The new rotors and pads (sorry for the dark pic):
    A view of the assembly through the wheel:
    The install wasn't too bad. Had to do some drilling to get the ghey screws out of the rear rotors. We had some problems getting the emergency brake reset, but nothing crazy. Anyway, it stops like a dream now. Plus, all the noise that was happening because of the low pads is gone. Many thanks to lsvtec and 93solman for their help this weekend.
    As a bonus, here is a pic of what camber does to your tires (without much toe, I have a lifetime alignment at Firestone and get it aligned all the time):
    It didn't help the the Kuhmo's wear like crap. But the moral of the story is: Get a camber kit kids!
  2. pissedoffsol
    moral of the story: khumoes suck :p
  3. Liquidblaze
    Liquidblaze Senior Member
    Huntsville, AL USA
  4. dohcvtec_accord
    The left lane
    Kuhmo's suck if you've got like 1/5479853 degree of camber or more. My dad runs Kuhmo's on his Stealth and they wear just fine.
  5. pissedoffsol
    khumoes suck if you don't want to plow everytime you turn either
  6. dohcvtec_accord
    The left lane
    I never noticed a problem turning. The only problem I had with them (aside from the wear issue) was that they rolled under during hard cornering, but I think that was probably because I went one size over for my rims, being as I mostly race at the drag strip.
  7. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    So did you buy new screws for the rotors? On my fronts, I just went without screws, the wheels will hold them on. Did not have an impact driver so I had to just toast the screws with a drill.
  8. dohcvtec_accord
    The left lane
    That's exactly what I did. Those rotors had never been touched back there, so the screws had to be drilled out. 4 screws and 2 drill bits later, everything was fine. :) Didn't replace the screws, the wheels should hold the rotors on there just fine.
  9. KrUsHa
    KrUsHa Senior Member
    davie florida
    nice dude but kumho's are a very good tire for the price!!
  10. pissedoffsol
    wtf? you're rotors are just chillen there?????????????
  11. dohcvtec_accord
    The left lane
    No, if you look at the pics, the rotors fit over the four studs on the hub, and get held onto the hubs by the wheels, which are being held on by the lug nuts.
  12. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Those screws just make installing the caliper easier. The lug nuts actually hold everything in place.
  13. GSRCRXsi
    MD
    where can you get new screws for the rotors, with out going to the dealer and paying 10 bucks per screw? will any other place have them?
  14. dohcvtec_accord
    The left lane
    I'm sure if you go to a comprehensive hardware store, you can find panhead tapered screws with the correct pitch and depth.
    But why?
  15. lsvtec
    The Honda dealer in Longmont sold those screws for $0.49 a piece.
  16. GSRCRXsi
    MD
    im gonna need some when i replace my rotors, cause the screws that are holding them on there now are gonna have to be drilled out, they are fucked and the head of it is all stripped so you cant get a screw driver on it
