when a vehicle is running and an alternator and /or battery cannot keep up with the demands of a car audio systems draw of amperage or whatever, and the amps start to fail/ run out of juice, would amps [that keep the wattage output constant when voltage drops such as JL Audio's] solve this problem or would a system require a high output alternator reguardless of the type of amp used? <_<
