92civicb18b1
The Trisexual
I'm just about finished swapping in my b18b1, but 1st my problem is when I rev it, it struggles a little bit, at around 1500 rpm, it hesitates up until around 2000 rpm. I think it may be just because I'm usin the stock DX ecu but I'm not sure. I dunno if it makes a difference but I do not have the shift linkage hooked up and I guess it's in gear cause when I let go off the clutch the speedo will also go up when I push the throttle. I can't tell you if the the hubs spin because I didn't put in the driveaxles yet.
