Powersteering help
dansace
Member
I am about to swap a b20 into my eg and would like to know if it is possible to retain the ps using the d-series pump. I would prefer to not use the b-series pump due to the line issues. Any input is appreciated.
.... a DelSol (DOHC) or CRV bracket should work.
Worst case, do a manual steer conversion... offset some of the weight of the big b (unless your running like 19"s or somthin).
best o luck
Curious (or more like) envious ... here in CA, it's illegal to use a SUV motor in a car.
You can use the B series pump and the lines will fit. Just did B16A into an EG Hatch and used the B series pump but had to use the tank neck on the pump and feed line from my D. It is a tight fit but its hella nice and looks awesome. Makes the motor look like it belongs there.
