PR3 or PW0
Andrew
Active Member
Are they identical, or is one better than the other?
(for b16a crx si)
Thanks
-Andrew
they are identical, however you cannot use a pw0 chip in a pr3 and vice versa. for some reason though, it seems like the pr3 has a slightly better fuel and timing map. i'm not sure if it's true but it feels like the pr3's usually pull harder than the pw0's... could be psychologic though :shrug2:
So given the choice between the two, I should go with the pr3 then eh?
Can't hurt if it helps any...
Thanks guys
-Andrew
