Prelude Suspenison On Accord
Discussion in 'HYBRID -> BA-BB /CA-CD' started by gezzuzz, May 23, 2003.
  1. gezzuzz
    gezzuzz Junior Member
    what suspenison and brake parts from a prelude(94) will transfer over to a accord(94)
  2. racerx h23
    racerx h23 Member
    TN
    If I remember correctly, the two share many of the same parts. I'd use hondaautomotiveparts.com to cross refference part numbers to see if stuff swaps.
  3. lsdh22
    lsdh22 Junior Member
    if you drop the h22 into the accord, you will need stiffer shock, spring. Eventually you might want to get bigger rotors. And of yeah, ya might through time need the change out the hub bearings if you lover the car, and get front and rear camber kits
  4. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    That's not true. The H22 weighs damn near the same as the F22 in the 94-97 Accords (same for the 98-02 Accords with the F23). You won't NEED new shocks, springs, hubs, rotors, etc. However, an upgraded suspension and/or brakes are desirable to handle the extra power of the H22, and for a well-rounded ride.
