PROBLEM h22a into 92 accord
digitalhav0c
swap h22a in to 92 accord car runs fine other than running rich & throwing map sensor cel tried swaping 5 map sensors and checked voltage map 5.02 & 5.06 don't know what could be causing this if you have any suggestions pls email me@ digitalhav0c@hotmail.com or post thanks in advance
Is there a filter on the intake? And is your temp guage consistent or does it bounce around?
are you sure you have the vacuum lines hooked up right...if the vacuum line for the map is hooked up to the back of the plenum instead of the top of the TB it will start and idle fine but run rich as hell and boggish then throw a MAP CEL after you start driving.
