Problem with an ECU
Discussion in 'ECU's, Electronics, and Tuning' started by Pneuma, Mar 13, 2004.
  1. Pneuma
    Pneuma Junior Member
    Alright well I had an H22a swap done on a 95 Accord LX and it came with the whole package. The problem is my ECU is redlining at 7000 or a little below and I want it to redline at 82-8500 now what ECU would I need to accomplish that task?And is there any extreme risk involved in doing that?
  2. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    If you do what you want, I hope you have another H22 sitting in your garage to replace the one you're gonna blow.
    Use a P28 converted to H22 specs
  3. Pneuma
    Well what can the engine rev to is what I'm asking? I don't wanna blow my engine... Definitely not if thats not the way I should go then I won't go that way...What advantages can I see out of the swap of an ECU. Does it just alter the time rev limit that the vtec kicks in at?
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    you need to have it built to handle that kind of rev limit.. did you build that head at all?
