Problem with gears
marek
The reverse gear in my stock 1990 ls teg is grinding everytime i try and put it in there without putting it in another gear first. Say i put it into any other gear first and than reverse, than it is fine. But if i step on the clutch and go straight for reverse it grinds. Is this a problem or what?
Originally posted by Bl6CRX@Apr 4 2005, 06:39 AM
Very common, not sure why, but I have seen many b series trannys like this.
[post=482385]Quoted post[/post]​
Can it be fixed? I have a similar fault in a newly overhauled Y1 lsd tranny. I can travel up the gears no problem even at speed but when I come back down them as you do when slowing for a junction, I can't get 3rd. It's like I haven't quite made the gear lever full throw, so that when you take the foot off the clutch and add power it slips out and makes a horrible whirring sound.
I'm going to adjust my clutch cable tonight to double check it but should I be speaking to the people who did my overhaul?
