Problem with starting, '95 B18c, Please help
Discussion in 'General Tech and Maintenance' started by NickQ, Jul 19, 2005.
  1. NickQ
    NickQ Member
    Wasn't sure wether this should go here, pr in the electrical forum, but anyway...
    I am having this problem with starting, on my B18c swapped hatch.
    When I turn the key to start the car, it does not start, it just "Clicks", similar to when you have a dead battery (which it isn't, cause I have a new battery). I can get it to start if I flip back and forth between start and on repeatedtly for about 10-20 seconds. It's not that the starter is spinning and it's not catching, it's that the starter is not even spinning. It's like the solenoid is clicking but the starter is not going.
    I thought for sure it was the solenoid inside the starter, so I got a new starter, but I am having the same problem. I checked the flywheel and starter gear to make sure there are no missing teeth, and there are not.
    I am absolutley dumbfounded. Maybe it's an easy fix many have encountered and I'm just missing it, but I am stumped.
    Please, any help is appreciated. Thanks very much.
