Problems after oil change
Discussion in 'General Tech and Maintenance' started by Liquidblaze, Oct 21, 2002.
  1. Liquidblaze
    Liquidblaze Senior Member
    Huntsville, AL USA
    I have a knocking sound when my car is cold. I switch to syntec blend oil this time. I know I have enough oil. I used the right viscosity, 5w-30. Does anyone think I should switch back and do another oil change? It only happens if my car has been sitting for a while and then the sound goes away after I drive down the street. Its as if the oil isnt being circulated as soon as I start the car. Could this synthetic blend be my problem?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Sounds like you need to do a valve adjustment. It doesn't have anything to do with the oil change. If your rockers are a little out then the sound will go away when the motor starts to warm up. I love the avatar.
  3. Liquidblaze
    Huntsville, AL USA
    I am going to check the valve tomorrow. If they are what they should be should I adjust them to a different spec?
  4. lsvtec
    The specs should be on your hood. I think it is .004" for the intake and .007" for the exhaust, but you should not take my word for it.
  5. pissedoffsol
    synthetic oil blows.
    change that shit out of there
  6. lsvtec
    Naw man, synthetic oil rocks. Takes much more to boil it. Lasts longer. Lubricates better. Etc.
  7. Liquidblaze
    Huntsville, AL USA
    well which one is it?[​IMG]
  8. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Car runs better and longer on synthetic.
  9. lsvtec
    The clicking is your valves. As for which oil to use that has been a "discussion" for as long as I have been a member of this board.
  10. knowledge
    knowledge Senior Member
    Beale AFB, CA
    i would use regular oil on a N/A motor. And synthetic on a turbo motor! Just because the turbo gets soooo damn hot and synthetic has a higher boiling point.
  11. lsvtec
    Why not use synthetic all around? I actually notice a difference with synthetic oil over dino, and no turbo here.
  12. phunky.buddha
    Dallas / Fort Worth, TX
    :werd:
    Dino oil won't last 100 miles in my engine... I torched a quart of dino oil that someone recommended I try in only 100 miles- let's just say that the car went straight up on stands as soon as I got back into town, and I dumped that dino crap straight out.
  13. Liquidblaze
    Huntsville, AL USA
    Well I feel pretty stupid. Everyone can laugh at me. Well, today I adjusted my valves but that didn't fix the problem. I found the problem though. Saturday I took off my header and put it back on, but I did not put it back on tight because I was getting a new header at the end of the week and i left everything loose for when I take it off again. It was a stupid exhaust leak. It goes away when the car heats up because the metal begins to expand and creates a better seal. I feel like a real dumbass. Sorry for all the heartache. Thanks for everyone help.
    Chris
  14. knowledge
    Beale AFB, CA
    lmmfao! Good find lol
  15. CRX-YEM
    Wallingford, CT
    hehe, header leaks sux0r.
