1st, you can put it in the correct forum, 2nd you can say what the fuck you swapped the b18 into... 3rd you can check the IAC valve located on the back of the intake manifold... what is the speedo doing? if it's jumpin, you didnt get it plugged into the gauge cluster all the way... and then you can calm down and reread your post so they actually make sense, a little more so than they do...
