Last year in June i installed a B18C (JDM) with P73 obd2a in my 1995 EG4. It all worked out well and nothing was wrong. Until 1-2 months ago. it suddenly lost half of its power. I have a Apexi RSM that showed 230hp before and now 70-100hp. The car is very driveable in the city and so, but when i put the pedal to the metal it has 1/2 of the normal power, and it struggels to hit the red mark. And if i shift at like 4000rpm it shots in the exhauste. There is no CEL code :cry2: Hope you guys are abel to help me This is what i have done so far: New Dizzy New Map sensor New Fulefilter New oil filter and oil. New Plugs *Did a compression test and all cylinders got betwen 210 and 220Psi (is that good???) Thanx For any Relpy Kristian Moe Norway. BTW: Sorry for my bad english
what mods do you have? this will help us find if something was installed wrong or might be causing issues.
Everything worked good :cry2: I have no mod exept exhaust and open air filter. A B18C is a good mod for me had a D15B2 (DPFI).
i dunno man. it's hard without many details. check the fuel pressure. get the timing checked. could be a clogged catalytic convertor.
