Hello everyone I would like to share with you My second Build, This time I am doing everything right so this will be a slow thought out process. I will be doing a auto to manual conversion as well as a B18b1 swap into this car. I will also be doing some JDM parts installs and hopefully if things go well a full suspension install.
This is "EJWONE' a 1993 Civic Ex Coupe
So here He is when Ej1Rider owned him.
Here He is on the trailer going home.
Here he is the first and last time for a while on the street with his gurl Elsie!
Now the build begins, here are the before shots
Crossed Drilled and Slotted Rotors came with it but there was this horrible noise when driving sounded like a bad axle, well it ended up being loose lug nuts and braking system. So I got 4 bad lug studs on the pass front.
I am taking the rotors to work with me tomorrow to resurface them I will then reinstall them on the car and prep it for the motor swap and conversion.
Stay Tuned!
::**UPDATE 29 JULY 06**::
Ok so today I went to work at 7 this morning and I got out at 4 I came home and started to work on the cars.
SO here is how it begins!
93 automatic D16z6
95 Integra 5 Speed B18B1 with exedy racing clutch and tricks to the trans!
The "Technicians"
Messing with something to get this bad boy out!
Chrissy hard at work
My Pops Watching Chrissy work LOL
Now what?
Use the Gun and take off the axle nut
Here is the right hand side wiring and everything but the motor mounts cleared out so it can be pulled
power steering pump disconnected from the motor brackets and everything out of the way getting it cleared so I can just drop it out!
Thats all for now as I am tired and Chrissy is too maybe tomorrow we will work on it some more.
Stay Tuned!
UPDATED 30 JULY 06
Ok so I got up this morning and I did not have plans to do anything with the cars today. Chrissy went to church and I was tired and stayed in bed well I got restless and got up got ready and went out side. I looked at the green coupe over and over again and I looked at what I had left to do.
It was not much just the drivers side axle and then the motor mounts so I got to it and I got it like this.
Up Up and away!
Rollin to her standby spot
Look Ma its empty
Powered By Dina!
Now to this!!!
More Progress:
drivers side torque mount removed
AC Compressor, condensor, fans and power steering removed
right side all disconnected except for mounts
Zero, Zip, Nada!
Here is the setup as it sits, I want to Thank Chrissy for supporting me and my Dad and Daughter for setting up the tent thingy and getting me water, the sun has taken its toll on me and has won for today.
So I wont touch the car again until maybe friday or saturday after work.
Stay Tuned!
Stay Tuned!
93 automatic D16z6
The "Technicians"
Now what?
Stay Tuned!
UPDATED 30 JULY 06
Up Up and away!
Look Ma its empty
Powered By Dina!
Now to this!!!
More Progress:
Zero, Zip, Nada!
Stay Tuned!
