PLA5151
Okay....I just swapped out my rear drums on my car and installed GSR discs (see sig) the problem i am running into is I have next to no clearance between my IM and my firewall where the proportioning valve is mounted. The GSR proportioning valve I have (off a '98 teg) sits outward where my HX valve is flat to the firewall, does anyone know an alternative proportioning valve I can use that will fit and keep my rear discs as functional as they should be....if not just another method to getting crap to work thanks in advance
