Pulling Codes
rodzilla
Member
i know you can pull codes with a paperclip on an obd 1 honda or acura, but how do you do it on a obd2? my friend has a 96 teg special edition that is throwing a check engine light. is it possible to pull a code?
same way.
check the articles section for more info and a code reference sheet
i looked for the jumper to insert the clip and could not find it. i will look again, but it is obd2, does that make a difference?
If it is in the same place as the OBD I,then it is at the bottom right side of the glove box,tucked up in there behind it,just above the carpet.
Here's a pic that might help you with locating it.
