pulling motor
Discussion in 'HYBRID -> EG-EK / DC' started by vtecsir1, Dec 31, 2002.
  1. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    i wanted to know if hoisting the motor from the top is easier than taking it out from the bottom, any other tips on pulling it would be great. the axles are off and the exhaust is unbolted from the header all that is left is for me to pull it. car is a 95 civic hb, thanks
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Do you have a lift?If so from the bottom is easier.If not then you don't have a choice eh?
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    the one good thing about getting it out from the bottom is you wont have to worry about any body damage.
  4. xj0hnx
    C.C.TX.
    Or hitting parts still mounted in the bay.But really if you only have a hoist,take off your hood and be careful and you'll be fine.
  5. vtecsir1
    Orlando, FL
    thanks guys the only thing i have been able to find is a hoist for 30 a day, do you think i could hoist the front of the car and pull the motor from underneath? put it on a wheel thing which i have and roll it out?
  6. vtecsir1
    Orlando, FL
    does anyone even rent lifts?
  7. asmallsol
    just rent the engine hoist and in two days you should be able to return it.
  8. xj0hnx
    C.C.TX.
    No because if you tilt the car it becomes harder to get the mounts to either come out or go back in lined up.As far as a lift are you in high school by anychance or near one?If so see if the auto shop will let you use theirs.
  9. vtecsir1
    Orlando, FL
    not in high school, but the one near me is real snotty and wouldnt let me do that so i'll just get the hoist. thanks again
  10. xj0hnx
    C.C.TX.
    Check your local mechanic or junkyard,I have found a few that during off hours are more than happy to rent out their lift.
