Q??? on civic hatch swap
Discussion in 'HYBRID -> ED-EF / DA' started by lilhoffmang08, Jul 18, 2009.
  1. lilhoffmang08
    lilhoffmang08 New Member
    Im going to swap in a different motor into my civic hatch either a b18a or a b20b i do alot of highway driving so i want one that will get fare gas mileage but still has power im thinking that the gas mileage would be better in the b18 but would sacrifice the mileage if the b20 would make up for it in power what do you think
  2. lilhoffmang08
    please i no someone out there has to no something
  3. blasterman87
    blasterman87 New Member
    either one should get over 30 mpg because of the light weight car...
  4. D16SiHatch
    D16SiHatch New Member
    you won't notice a difference between the two. you could get 30+ mpg with a type-r swap. its all about being able to keep your foot out of it. also take into consideration what transmission you'll be using. a gsr trans for example would make your car faster, however leave your car sitting at higher rpms while on the freeway. if you can live with the slightly longer gears of an ls then you will also benefit from the lower rpm while highway driving.
  5. Dark93DX
    Dark93DX New Member
    B.C.
    :ditto:
