tommynrossie
Hello, I just have a couple of questions regarding a swap im in the process of doing. I have a 95 accord f22b1 and came across aan h22a4 that I plan to drop in. 3 things I can see that may be a problem are 1-the coil on my accord is internal and the h22a4 runs an external coil. can it be modified to use the external coil? 2-The crank sensor on the accord I beleive is internal to the distributor as well, the h22a4 is at the harmonic balancer. can it also be wired in and used? and lastly 3-the throttle cable linkage at the manifold on the accord mounts in a different place than on the h22a4. is there a way to remedy this or do I need the throttle cable for the h22a4? sorry to be so in depth about it but any help would be greatly appreciated.
