question about my build
DoinWork
Member
bl6 block itr crank rods and pistons
itr head, toda everything
basic bolt-ons
will this net me 200whp with tuning and the right ecu?
basic bolt-ons
[post=465493]Quoted post[/post]​
it wont. the b16 setups will need more compression and a more built head setup.
B18 and LS/VTEC setups are known to make 10-20hp more than similar b16a setups.
well first off, have fun trying to put an itr crank rods and pistons in a b16 block. won't happen. If you meant a b18 block and toda C's a good header then maybe 200
itr internals in a b16 block = oooops, my piston just went through my head.
agreed. and 200 whp out of a b16 is not an easy task.. too much money for what its worth. look into that b18 block. i netted an addition 30 ft-lbs of tq and 20 whp just by swapping the block.. no change in the head or other bolt ons...
I was just trying to make the most power out of a b16.
My friend got an almost similar setup,if any of you from jersey then you know who dennis is...
I have an ls block but i know the b16 will happen the high-revs allday...
Thanks for the input
[post=465945]Quoted post[/post]​
im from jersey and i dont know any dennis. where in nj?
Dennis the hillside cop... You must not know the street scene, he ran 12.1's all-motor... now he's running 10's in his turbo hatch... byt and drt put it together...
