question for everyone for this idea
Discussion in 'ECU's, Electronics, and Tuning' started by Dancomer, Apr 11, 2004.
  1. Dancomer
    Dancomer Senior Member
    Gurnee, IL
    is it possible to use a mas airflow sensor before the throttle body for my boost setup so i do not have to worry about the map sensor reading boost? and yes i know i could just use a missing link or check valves...but is it possible and can i do it with a factory computer?
  2. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    I doubt it, they work differently and require different inputs.
    Mass Airflow = warms a small wire in the intake stream and tests the impedance caused by the wires temperature at different throttle positions.
    Manifold Absolute Pressure = measures manifold pressure oddly enough.
    If your gonna use hondata for fuel management you can use a GM 3 bar map sensor. Then youll have a good setup with no check engine codes or anything.
  3. pissedoffsol
    maf or map, the stock honda ecu doesn't have boost ingition and fuel tables. it doesn't know what to do with it once its out of mHg
  4. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    using a MAF with a stock ECU would be an exercise in futility. You might as well re-write the ECU's program from scratch.
  5. HardLowrdRanger
    HardLowrdRanger Member
    Phoenix, AZ
    Ya, this kid is funny... When I turbo'd my truck I got rid of the MAF and went MAP... You're a very troubled individual dude... If you want to run boost on your stock ECU go to www.pgmfi.org get the DIY tools and keep your map sensor! :p
