question
95civicb16
Im building a b16a3 With a 13.2 to 1 compression pistons what brand and stage cams should i go with. i want it to be street or strip.
at least '2', but most companies 'stages' will vary greatly. Most will list a working compression range for their grinds.
you should tune on whatever your tuner is comfortable with. Plan to visit a dyno, and show up with larger injectors
yea i got bigger injectors fuel pump and regulator im trying to make this as fast as i can with out boost.
