question
Discussion in 'Integra' started by TegraDoc, Oct 21, 2007.
  1. TegraDoc
    TegraDoc New Member
    Tx
    ok, I installed a CAI not too long ago, 2 weeks maybe, and noticed a decent change in performance, yesterday I installed skunk2s intake manafold and was expecting another decent change in performance, yet, I am not noticing that much. Will I see it more when I add headers and exhaust? is the intake only getting as much as it can without changing exhaust or cams or what? those are the only two mods I have on my 2000 teg. Any help would be great. Thanks
  2. norcalgsr
    NorCal
    Intake manifold will not help much on a stock engine. Adding a header and a larger exhaust will help, but to really see an improvement you need to replace the cams also to make your engine draw in more air. Then you will probably see a very large improvement in power since you already have those parts installed.
  3. c97x
    c97x sorry boss, its turbo
    the skunk2 intake mani is more for top end power as well, i mean sure it flows nicely but its more for upper rpm range. whatever happend to you going turbo?
  4. quikstr13
    quikstr13 New Member
    is ur teg.... a b18b or b18c????
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    dont forget that you need to compensate for more airflow with more fuel..get a little bigger injectors,cams,and header
  6. norcalgsr
    NorCal
    Wrong.. bigger injectors are not needed unless he is running very high compression N/A build or boost. And the cams/header was already covered.
