Questions about hooking up an amp.
Discussion in 'Car Audio / Security / Electronic Accessories' started by wikedeye, Mar 20, 2011.
  1. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    I have a kenwood kac-ps150 thats been sitting in my garage for a while. I thought I could hook it up to the mids in my car (4 x 4.5'"). It has been ten years or so since I did any car audio. What size power and grnd wires should I use. I have enough 10g power wire and an 8g ground I believe. What size inline fuse should I use? The amp has two 20amp fuses. Also would this be enough amp for four speakers? What would be the best way to hook them up? I am pretty sure that the speakers are 8ohm. I guess I would have to hook up two speakers per channel. Any advice will be appreciated. Thanx.
  2. wikedeye
    Savannah, Ga.
    Anyone have any advice.
  3. jamesA
    What kind of amps are the four speakers combined supposed to draw?
  4. wikedeye
    Savannah, Ga.
    I am not exactlly sure how many amps. They are older kenwood 4.5" speakers, 4 of them.
  5. jamesA
    If you can get the model number we could probably look up the power draw.
  6. wikedeye
    Savannah, Ga.
    K I will look when I get home in a bit.
  7. wikedeye
    Savannah, Ga.
    They are kenwood kfc-1679ie. 160w peak power. 4 ohms.
  8. Taco15
    Tallahassee Fl
    the 10awg will work fine although I would run the 8awg in case you ever need upgrade.
    40-50 amp fuse should be enough too.
  9. wikedeye
    Savannah, Ga.
    I dont have enough of the 8g wire to run for power. I dont really plan on adding a sub any time soon so I think I will use the 10g. You say 40-50 fuses will work, but which would be safer in case of a power surge? Will I run into problems trying to hook up 2 4ohm speakers to each of the two channels.
