Questions
Discussion in 'Engine Building' started by mattcalica, Jan 3, 2003.
  1. mattcalica
    mattcalica Senior Member
    okay, first question...i have a b16a, will a b18a head gasket fit on it? second question...when pulling out my motor, i broke a cable coming out of the back of the tranny...it wasnt the clutch cable, what cable is it? last question, when i took out the motor, i creased my shift linkage...is it fixable, my brother can weld, so can i just reweld it?
  2. SixtySecondAssassin
    Austin, TX
    maybe you broke your speedo cable.
  3. cws13
    cws13 Senior Member
    Athens,GA
    Use the right head gasket for the head, and you broke your speedo cable.
  4. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    bingo
